13 years agoSignalTap II sampling mechanism and clock frequency is bound to correct synchronous timing as other design entities. If you are sampling signals in clock domains with known timing relation to the sampling clock, timing analysis will tell you about correct timing. But it can't for unrelated clock domains. Signals sampled from an unrelated clock domain are not becessarily consistent.
