Intel FFT simulation was failed in 2 Matlab version
Hello Sir/Madam,
Quartus prime pro 17.1 + Modelsim 10.5c +Arria10gx
Intel FFT IP core , Variable Streaming,N=256,data type is single.
I generated an Intel FFT ipcore from Quartus, I can see some Matlab <variation name>_model and <variation name>_tb files have been generated under my nominated location E:\gofft\tfft\altera_fft_ii_171\sim\Matlab_model\
Following the simulation instruction, 2.5.2. Simulating the Variable Streaming FFT IP Core in the MATLAB, on page 24 of ug_fft.pdf. I got something wrong as below
>> nps=[256,2048];
inverse = [0,1];
>> x = (2^12)*rand(1,sum(nps)) + j*(2^12)*rand(1,sum(nps));
>> [y] = tfft_altera_fft_ii_171_tp3vvyi_model(x,nps,inverse);
Invalid MEX-file
'\\client\e$\gofft\tfft\altera_fft_ii_171\sim\Matlab_model\SVSfftmodel.mexw64': Access is
denied.
Error in tfft_altera_fft_ii_171_tp3vvyi_model (line 47)
[roc,ioc] = SVSfftmodel(rin,iin,DATA_PREC,TWIDDLE_PREC,N,nps(i),inverse(i), INPUT_ORDER,
OUTPUT_ORDER,REPRESENTATION,SVOPT,PRUNE);
Because I have noticed some old answer for similar question mentioned this simulation only support 32bit Matlab. So I have tried this test on below 2 platform,
Both 2 platform,I got same error information .I have restart matlab and computer ,and issue still same.
Cast case 1 :Win10 + MatlabR2019b
Cast case 2 :Win7+ Matlab6.5.1
Any suggestion is welcome
Jim
- User1582192733150209
my matlab files generated by IP tools , you can try it on you own platform to see if you can duplicate my issue.
- CheepinC_altera
As I understand it, you encounter some issue when trying to simulate the Matlab model generated together with the IP HDL generation. For your information, can you try the following:
1. In your FFT IP, Generate the Example Design
2. In the generated folder ie fft1_ii_0_example_design, look for Matlab_model folder
3. You can find the model.m and _tb.m in the folder
4. Try run the Matlab simulation using these files.
Chee Pin
Hi Chee pin,
Thansk for your support.
Unfortunately, there is no option to generate a example as below.
- CheepinC_altera
thanks for your update. As I further debug into this, I notice that there is no example design generation for A10 FFT in QPro. As a workaround, you can try to use Quartus Standard Edition to generate the example design. I have emailed you a ZIP of the example design generated with Q17.0Std for your reference. Sorry for the inconvenience.
