User1582192733150209
6 years agoIntel FFT simulation was failed in 2 Matlab version
Hello Sir/Madam, Quartus prime pro 17.1 + Modelsim 10.5c +Arria10gx Intel FFT IP core , Variable Streaming,N=256,data type is single. I generated an Intel FFT ipcore from Quartus, I can see some ...
CheepinC_altera
6 years agoHi,
thanks for your update. As I further debug into this, I notice that there is no example design generation for A10 FFT in QPro. As a workaround, you can try to use Quartus Standard Edition to generate the example design. I have emailed you a ZIP of the example design generated with Q17.0Std for your reference. Sorry for the inconvenience.
