18 years ago
Instantiation Components Compile error
I'm new to Quartus 6.1 Web Edition software. I bought the CYCLONE FPGA Starter Board and tries to learn how to use Quartus 6.1 that came with the board.
The problem I'm having is with my functions, parts and component libraries. For example, when I try to compile the following VHDL code which is a FULL_ADDER, I keep getting the following error message :
vhdl error at full_adder.vhd(18): object "xor_3" is used but not declared
Before compiling the code, I've included the necessary libraries during the project creation. Despite everything I've tried, I'm still getting the same error message. It does not matter whether I include or not the use clauses for the libraries needed in my root page, I get the same error message. It just does not see my instantiated components.
I've to stress that the same code compiles and runs on ORCAD FPGA Simulation, but not on QUARTUS. Why is it so difficult to get things run normally with Quartus while they run smootly on all other simulators I've been working on so many years? - Strange...
I've followed all Quartus recommandations on the subject and I'm still anable to solve this issue.
Thanks to show me what to do in order to use my libraries with QUARTUS. Below is the program without the parts and components libraries needed.
library ieee;
use ieee.std_logic_1164.all;
-- I do not have to use the parts and components libraries below with ORCAD.
--library parts_lib;
--use parts_lib.all;
--library comp_pkg;
--use comp_pkg.all;
entity full_adder is
port(
a, b, cin : in std_logic;
sum, co : out std_logic
end full_adder;
architecture full_adder_arch of full_adder is
signal sig1, sig2, sig3 : std_logic;
begin
U1 : component xor_3 port map(
x1 => a, x2 => b, x3 => cin,
y => sum
U2 : component and_2 port map(
x1 => a, x2 => b,
y => sig1
U3 : component or_2 port map(
x1 => a, x2 => b,
y => sig2
U4 : component and_2 port map(
x1 => sig2, x2 => cin,
y => sig3
U5 : component or_2 port map(
x1 => sig1, x2 => sig3,
y => co
end full_adder_arch;
    You are right, Quartus II Synthesis is not able to generate logic to implement a dual-edge register in a device. So you may need to use a double-frequency clock and work on its positive edges instead.
    Another way could be to use two separate process blocks as follows
    ARCHITECTURE arc OF test1 IS
    begin
    process (C)
    begin
    if (C'EVENT and C='1') then
    if V='0' then
    A <= '1';
    else
    A <= '0';
    end if;
    end if;
    end process;
    process (C)
    begin
    if (C'EVENT and C='0') then
    end if;
    end process;
    end arc;
    Of course you will have to fill in the suitable sequential statements in the last if block.
    You must not necessarily use two process blocks, but it improves readability, I think.
    As you previously mentioned, you can't have dual-edge sensitive registers. So you need separate registers for both edges and asynchronous logic to combine both register outputs. There are classical examples as factor 2.5 clock dividers. Some precaution is necessary to avoid glitches in this kind of design.
    YES, it works with 2 process!!!:):p
    Actually, use dual-edge sensitive registers is allowed in VHDL without Quartus II? Can we use all VHDL'syntaxs possible with Quartus II?
    Really thank you FvM.
    Every Integrated Synthesis tool has limitations compared to the official VHDL and Verilog implementations so typically not every construct is synthesizable by all the tools. This limitation is due to the Quartus II synthesizer, but as you have seen here, there are some workarounds which help you synthesizing the dual-edge logic as well.
    The restriction basically isn't by Quartus but by the FPGA hardware. It's similar with any other vendors FPGA or ASIC. The only unrestricted usage of HDL is in simulation. Here you can define delays without needing a clock or design dual-edge sensitive registers.
    To my opinion, it's important to understand how a HDL construct can be inferred in FPGA hardware, cause it helps you to avoid such constructs, that behave different in simulation and synthesis.
