Initialising RAM instance with (.mif)
Did you put the file into your testbenches?
Here is the source https://www.youtube.com/watch?v=gRzqcL1CwfE
Thanks for the reply and the source.
Unfortunately I have no luck with your suggestion.
It may be useful to note that I am using the Questa RTL simulator and not modelsim, however, I do not think that this is significant.
Continuing to solve the issue, I have performed the following suggestions from the following forums.
RTL Simulation cannot find MIF
Attempts:
1. I am confident that the formatting of either the .mif/.hex file is correct.
2. I am confident that Questa can "read" the .mif/.hex file, as no error output is shown in the compilation messages in Questa
3. I have also experimented with placing the 'sram256.qip' and the `.mif` files in the same directories, as shown below:
- Project top-level
- Memory directory (project_dir/memory)
- Simulation directory (project_dir/simulation/questa)
Still no luck from the suggestions.
Any other suggestions are appreciated.
Thanks in advance.
