17 years agoIncremental Place and Route
Hello, I’m new in all of this so I need your help. The problem is the following:
I’m working with Quartus II 7.2 and the device I’m using is a Cyclone II. Well, suppose that I have a system A and I put it into the Cyclone, in order to test it I place a Sources and Probes block, called SP. If I see the chip planer (in Quartus) I see A in the corner of de FPGA. When I see the chip planner after adding the SP block A and SP are in the middle of the chip. So this, changes the skew of the signals in A and this is bad for me, very bad. So I want the system A to stay in the original place after I add the SP. How can I do that? I hope the explanation was clear. So thanks for all. Ignacio.
