--- Quote Start ---
Hi Pletz
The purpose of the block SP is connect the design with a PC, because I have 10 binary inputs and I haven’t 10 switches on the board.
Yes, I only use one clock at time, but the output needs that the skew of this signal be almost 0.
Thanks Pletz
Ignacio
--- Quote End ---
Hi Ignacio,
I don't know your design, but when I assume that your design uses one clock at time and is synchronous, you only could have a problem in your input ( setup times) or output ( clock to output) timing. Why do you need a skew of almost 0 ? Is it a requirement of the input or output timing ?
Kind regards
GPK
