17 years ago
Incremental Place and Route
Hello, I’m new in all of this so I need your help. The problem is the following:
I’m working with Quartus II 7.2 and the device I’m using is a Cyclone II.
Well, suppose that I have a system A and I put it into the Cyclone, in order to test it I place a Sources and Probes block, called SP. If I see the chip planer (in Quartus) I see A in the corner of de FPGA. When I see the chip planner after adding the SP block A and SP are in the middle of the chip. So this, changes the skew of the signals in A and this is bad for me, very bad.
So I want the system A to stay in the original place after I add the SP. How can I do that?
I hope the explanation was clear.
So thanks for all.
Ignacio.
    Timing Constraints are considered the way to go, because a) they guide the fitter in it's choices and b) they give clear feedback on whether constraints were made or not. Just because some logic was placed close to some other logic, you still have no idea if it really met timing.
    What skew can you handle? I haven't seen that posted, and it could make a huge difference. Also, what are the clock rates? If this is something where you can physically control with signals and probes, then it's probably slow enough that it doesn't matter. Since that uses the JTAG port, it clocks the data in serially and then does one clock to do a parallel transfer(I haven't looked at it, but assume this is the way it works), which is mighty slow. And you can constrain your clocks as so:
    Look at the middle example of:
    http://www.altera.com/support/examples/timequest/exm-tq-clock-mux.html
    Just make it 3 clocks. Of course, if you're just switching between asynchronous clocks you will have clock glitches. That's one of the major reasons everyone is so against this. If you can, either disable all the logic while switching(perhaps have a clock enable).
    --- Quote Start ---
    Rysc:
    Thanks, I’m reading this information.
    bye
    Ignacio
    --- Quote End ---
    Hi Ignacio,
    maybe now I got what you are doing with the SP-Block. You have in your design some inputs dangling and you are stimulating these inputs with the SP-Block ??? What is the purpose of this input, when you have no input signal for them ?
    But why do you have a skew problem with the clock ? You always use only one clock at time, so where is the problem. Of course have to constraint them like Rysc described in his post.
    Hi Pletz
    The purpose of the block SP is connect the design with a PC, because I have 10 binary inputs and I haven’t 10 switches on the board.
    Yes, I only use one clock at time, but the output needs that the skew of this signal be almost 0.
    Thanks Pletz
    Ignacio
    --- Quote Start ---
    Hi Pletz
    Thanks Pletz
    Ignacio
    --- Quote End ---
    Hi Ignacio,
    I don't know your design, but when I assume that your design uses one clock at time and is synchronous, you only could have a problem in your input ( setup times) or output ( clock to output) timing. Why do you need a skew of almost 0 ? Is it a requirement of the input or output timing ?
    Kind regards
    GPK
    Hi Pletz,
    The problem is in the output signal, because it use one of the clock at time, and this clock is select for the inputs. So in the output you can see the deferens between the clocks, hence if this deferens are different that I want, so is wrong.
    Thanks Pletz
    Ignacio.
    --- Quote Start ---
    Hi Pletz,
    Thanks Pletz
    Ignacio.
    --- Quote End ---
    Hi Ignacio,
    I don't get want mean. Is it possible to post a small drawing of your design to get an overview. Sorry that I'm not able to get it without it.
    Kind regards
    GPK
    Hi Pletz I'm sorry. I was searching the authors of the paper that I used but they don’t answer my mails. My idea was give you this paper so you can understand the problem perfectly.
    If they respond me I’ll tell you.
    Merry Christmas and Happy New Year.
    Thank you
    Adios
    Ignacio.
    --- Quote Start ---
    Hi everyone, I have an answer for the authors of the paper and you can see it in:
    http://ieeexplore.ieee.org/xpls/abs_all.jsp?isnumber=4712525&arnumber=4663501&count=59&index=51
    Thanks Sr Angel de Castro
    Adios.
    Ignacio.
    --- Quote End ---
    Hi Ignacio,
    unfortunately I have no access to the document without buying it. What I could see in the summary was that they used a XILINX FPGA which includes a DLL. It looks tome that they used the DLL in there design.
