15 years ago
'Illegal directional connection'error in Quartus 8.0
Hi all.
Recently I compile a project in Quartus 8.0, it comes out the errors:
Error: Illegal directional connection from the node "WPI_MODEL:inst|AnalogFault:I52|data_out[2]" to the pin "XD[2]"
while compile in Quartus 5.0, it's Ok.
I look for a long time but find nothing.
Could somebody help me for this situation?Thanks a lot.
    I don't know what an "Illegal directional connection" exactly is. Is it a compiler or fitter error message?
    I would primarly look for the logic definition and possibly defined pin attributes and other specific assignments. I also would try with a newer Quartus version, e.g. a stable 9.0.
    --- Quote Start ---
    --- Quote End ---
    In my project,I define a 'INOUT' , and the project is well run in Quartus 5.0.Now I want to compile in Quartus 8.0, during the systhesis it get errors.
    Best Regards!
    I have defined a 'inout' in top module
    data : INOUT std_logic_vector (15 downto 0);
    and then I call a component and use the data as bidiretional interface.
    port map
    (data_in=>data,
    data_out=>data,).
    I don't know the port type of data_out, but this most likely can't work. You'll need a tristate driver interface.
    port map
    (data_in=>data,
    data_out=>data_o);
    data <= data_o when (enable_condition) else (others => 'z');
    P.S.: If data_out is of the output type, and you simply want to override the inout character of data (permanently enable the output buffer), there may be technical problem of the Quartus compiler. In this case, try to insert a dummy signal between data_out and data.
    --- Quote Start ---
    port map
    (data_in=>data,
    data_out=>data_o);
    --- Quote End ---
    Thanks a lot!
    data_out is defined as 'output', I still confused that my project is no problem during Quartus 5.0 environment.I doubt that the version of Quartus 8.0 don't support some VHDL grammar anymore.
    Besides I am not familiar with VHDL, so I'm not sure
    port map(
    data<= data_o when (enable_condition) else (others=>'z')
    can be complied without errors or warnings.
    Thank you very much!
    you cant compile it directly into a port map.
    data would the the top level I/O, with data_o being a temporary signal inside the architecture.
