ID 12006 Undefined entity
Hi just a quick run down of what im trying to achieve write a value to my verilog code and read back the double value (input*2) gonna expand later on...(im new to FPGA)
ive greated a Qsys module as described here: ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/making_qsys_components.pdf the plan is the write/read a value from NIOS (hello_world) template to the new component(modified to return 2* input value, and removed the HEX output). 1.) Qsys module created (ok) 2.) Qsys generate HDL (ok) 3.) Nios project (debug via JTAG) (ok) -c code function returns same value as writtenvoid MyReadWrite(void)
static int writeval = 22;
int readval = 0;
IOWR(REG16_AVALON_INTERFACE_0_BASE,0,writeval);
readval = IORD(REG16_AVALON_INTERFACE_0_BASE,0);
printf("\n Reg16 Test WriteVal: %d, ReadBackVal: %d",writeval,readval);
writeval++;
reply in NIOS concole: Reg16 Test WriteVal: 22, ReadBackVal: 22 (i think i just write/read to memory somewhere without entering the verilog code. i havent compiled the FPGA code(Quartus project to get a .sof file) yet, at least i dont think so not 100% sure of whats include when i launch a debug session from eclipse) 4.) created a Quartus project (ok) containing the following files: -nios_setup.qip -MyReg16_avalon_interface.v -MyReg.v -top.v -platform/alt_pll/alt_pll.qip top.sdc 5.) when i try to compile the project i get the following error " Id 12006 instance "comb_4" instantiates undefined entity "nios_setup" (Guess i need to add something to my top.v file just dont know how/what t o add.) my top.v is a from the ADC demo in the design store. module top (
input clk,
input reset,
input SW,
output LED
wire adc_10M_clk;
wire nios_50M_clk;
wire pll_locked;
wire reset_n;
assign reset_n = !reset;
all_pll alt_pll_inst (
.areset ( reset ),
.inclk0 ( clk ),
.c0 ( adc_10M_clk ),
.c1 ( nios_50M_clk),
.locked ( pll_locked )
nios_setup (
.clk_clk (nios_50M_clk), // clk.clk
.reset_reset_n (reset_n), // reset.reset_n
.led_io_external_connection_export (LED), // led_pio_external_connection.export
.sw_io_external_connection_export (SW), // switch_pio_external_connection.export
.modular_adc_0_adc_pll_clock_clk (adc_10M_clk), // modular_adc_0_adc_pll_clock.clk
.modular_adc_0_adc_pll_locked_export (pll_locked) // modular_adc_0_adc_pll_locked.export
endmodule
any explanation on how to make this work would be appreciated. thanks in advance8 Replies
I don't know the solution, but please edit your post so that you have your code in code tags. This makes reading it much easier.
Here is the error:
nios_setup ( If you look at how you did your pll you have, all_pll alt_pll_inst( module ----- instance your nios_setup declaration is missing either the module name or the instance name - Altera_Forum
Hi code tags added :-) thanks for the heads up.
ATT: Krasner ive looked in some different demo project (all working fine) and they all share the same syntaks, " nios_setup ( " so i guess thats okay ? here is the verilog code:
For now this one just returns "11" no matter what input.module reg16_avalon_interface (clock, resetn, writedata, readdata, write, read, byteenable, chipselect); // signals for connecting to the Avalon fabric input clock, resetn, read, write, chipselect; input byteenable; input writedata; output readdata; // signal for exporting register contents outside of the embedded system wire local_byteenable; wire to_reg, from_reg; assign to_reg = writedata; assign local_byteenable = (chipselect & write) ? byteenable : 2'd0; reg16 U1 ( .clock(clock), .resetn(resetn), .D(to_reg), .byteenable(local_byteenable), .Q(from_reg) ); assign readdata = from_reg; endmodule
do i need to add Reg16 to my nios_setup ? and how ?module reg16 (clock, resetn, D, byteenable, Q); input clock, resetn; input byteenable; input D; output reg Q; integer bob; always@(posedge clock) if (!resetn) Q <= 16'b0; else begin // Enable writing to each byte separately //if (byteenable) Q <= D; //if (byteenable) Q <= D; Q <= 16'd11; end endmodule - Altera_Forum
Also when i create a new project in Nios-eclipse based on my new Qsys file (with the Reg16 component), do i need to load anything to the FPGA og is the debug via JTAG taking care of that ?
If you are asking, Do I need to reload the hardware, yes you will need to resynthesise the hardware and then reload.
as in .sof or .pof file with Flash programmer ?
Yes, indeed.
so after a little magic with filenames vs. component names its running fine now (Thanks for helping)... Im using a Avalon slave and using writedata(16 bit) as input to my vhdl block. What is the correct/best way to expand the input to be fx. 5 variables*16bit?. Is it to have 5 avalon_slaves or how is done properly ?
