11 years agoID 12006 Undefined entity
Hi just a quick run down of what im trying to achieve write a value to my verilog code and read back the double value (input*2) gonna expand later on...(im new to FPGA) ive greated a Qsys modul...
11 years agoHi code tags added :-) thanks for the heads up.
ATT: Krasner ive looked in some different demo project (all working fine) and they all share the same syntaks, " nios_setup ( " so i guess thats okay ? here is the verilog code:
module reg16_avalon_interface (clock, resetn, writedata, readdata, write, read,
byteenable, chipselect);
// signals for connecting to the Avalon fabric
input clock, resetn, read, write, chipselect;
input byteenable;
input writedata;
output readdata;
// signal for exporting register contents outside of the embedded system
wire local_byteenable;
wire to_reg, from_reg;
assign to_reg = writedata;
assign local_byteenable = (chipselect & write) ? byteenable : 2'd0;
reg16 U1 ( .clock(clock), .resetn(resetn), .D(to_reg), .byteenable(local_byteenable), .Q(from_reg) );
assign readdata = from_reg;
endmodule
For now this one just returns "11" no matter what input. module reg16 (clock, resetn, D, byteenable, Q);
input clock, resetn;
input byteenable;
input D;
output reg Q;
integer bob;
always@(posedge clock)
if (!resetn)
Q <= 16'b0;
else
begin
// Enable writing to each byte separately
//if (byteenable) Q <= D;
Q <= 16'd11;
end
endmodule do i need to add Reg16 to my nios_setup ? and how ?
