I enabled encrypted bit stream with a key and programmed encrypted POF file with ekp file on max10. The program is running well on FPGA. I can not full erase any more the FPGA..
I also can not any further program the FPGA. it always fails in Program/Configure. I can not also do Verify/Blank Check.
I can ONLY erase CFM0 and UFM....it shows 100% successful on progress bar. But nothing happens on FPGA. My program continues to run..
What could be the issue..I am attaching the images..
Appreciate pointers..
- Ms_G
Hi Vj, Vicky,
Yes I tried today, it does not seems to work. Once conf_done pin is low when powered, FPGA is not running the loaded bit stream as expected.
I tried to erase the chip in this state, it does not erase..after removing the low also I tried it does not perform erase.
Any thing I m missing?
Thank you
- Vicky1
Have you enabled the JTAG secure mode in the pof file?
Refer the "3.3.2.2. Generating .pof using Convert Programming Files" from link below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Which Quartus Edition(lite/std/pro) , version & Kit used
Vikas
- Ms_G
Hi Vicky,
Yes, I had JTAG Secure mode enabled. I did that after I had quartus.ini file placed under project folder. I was able to enable option for JTAG secure mode, in Convert Programming Files.
I guess problem started just after enabling JTAG Secure mode.
I use Quartus 18.1 lite with a license file for enabling encrypted bit stream..I was able to program and reprogram until I enabled JTAG secure mode.
I cant follow steps related to instantiating internal JTAG.. to disable JTAG secure mode.
Its a custom design board...I have two boards stuck with this situation. I can not program/configure anymore..
Highly appreciate your help on this to resurrect these boards :)
Thank you
Guna
- Vicky1
Hi Guna,
Please try to perform the below steps,
- Auto Detect
- Please don`t add any file
- simply perform full Erase
- Then add another .pof file to program.
please let me know , how it works for you.
Vikas
- Ms_G
Hi Vikas, No, I tried this..it did not work.
- vj123
Hi Guna,
Try to power up the device/custom design board by holding the "CONF_DONE" to low.
Please refer the below link & perform the action once you fully understood,
https://fpgawiki.intel.com/uploads/5/5f/MAX10_JTAG_Secure_Unlock_UG.pdf
- Ms_G
Thank you Vj, I dont know how to follow this very well..
I also found this..https://fpgacloud.intel.com/devstore/platform/15.0.0/Standard/max10-jtag-secure-unlock/
Again, not sure how to get this going. Could you help out on this.
Thank you
- Vicky1
Have you checked with "CONF_DONE" as suggested in previous post?
Any observation..
Vikas
