Ms_G
7 years agoI enabled encrypted bit stream with a key and programmed encrypted POF file with ekp file on max10. The program is running well on FPGA. I can not full erase any more the FPGA..
I also can not any further program the FPGA. it always fails in Program/Configure. I can not also do Verify/Blank Check. I can ONLY erase CFM0 and UFM....it shows 100% successful on progress bar. B...
Vicky1
7 years agoHi,
Have you enabled the JTAG secure mode in the pof file?
Refer the "3.3.2.2. Generating .pof using Convert Programming Files" from link below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Which Quartus Edition(lite/std/pro) , version & Kit used
Vikas
