Ms_G
7 years agoI enabled encrypted bit stream with a key and programmed encrypted POF file with ekp file on max10. The program is running well on FPGA. I can not full erase any more the FPGA..
I also can not any further program the FPGA. it always fails in Program/Configure. I can not also do Verify/Blank Check. I can ONLY erase CFM0 and UFM....it shows 100% successful on progress bar. B...
Ms_G
7 years agoHi Vicky,
Yes, I had JTAG Secure mode enabled. I did that after I had quartus.ini file placed under project folder. I was able to enable option for JTAG secure mode, in Convert Programming Files.
I guess problem started just after enabling JTAG Secure mode.
I use Quartus 18.1 lite with a license file for enabling encrypted bit stream..I was able to program and reprogram until I enabled JTAG secure mode.
I cant follow steps related to instantiating internal JTAG.. to disable JTAG secure mode.
Its a custom design board...I have two boards stuck with this situation. I can not program/configure anymore..
Highly appreciate your help on this to resurrect these boards :)
Thank you
Guna
