Ms_G
7 years agoI enabled encrypted bit stream with a key and programmed encrypted POF file with ekp file on max10. The program is running well on FPGA. I can not full erase any more the FPGA..
I also can not any further program the FPGA. it always fails in Program/Configure. I can not also do Verify/Blank Check. I can ONLY erase CFM0 and UFM....it shows 100% successful on progress bar. B...
Ms_G
7 years agoHi Vj, Vicky,
Yes I tried today, it does not seems to work. Once conf_done pin is low when powered, FPGA is not running the loaded bit stream as expected.
I tried to erase the chip in this state, it does not erase..after removing the low also I tried it does not perform erase.
Any thing I m missing?
Thank you
