Ms_G
7 years agoI enabled encrypted bit stream with a key and programmed encrypted POF file with ekp file on max10. The program is running well on FPGA. I can not full erase any more the FPGA..
I also can not any further program the FPGA. it always fails in Program/Configure. I can not also do Verify/Blank Check. I can ONLY erase CFM0 and UFM....it shows 100% successful on progress bar. B...
Ms_G
7 years agoThank you Vj, I dont know how to follow this very well..
I also found this..https://fpgacloud.intel.com/devstore/platform/15.0.0/Standard/max10-jtag-secure-unlock/
Again, not sure how to get this going. Could you help out on this.
Thank you
