Ms_G
7 years agoI enabled encrypted bit stream with a key and programmed encrypted POF file with ekp file on max10. The program is running well on FPGA. I can not full erase any more the FPGA..
I also can not any further program the FPGA. it always fails in Program/Configure. I can not also do Verify/Blank Check. I can ONLY erase CFM0 and UFM....it shows 100% successful on progress bar. B...
vj123
7 years agoHi Guna,
Try to power up the device/custom design board by holding the "CONF_DONE" to low.
Please refer the below link & perform the action once you fully understood,
https://fpgawiki.intel.com/uploads/5/5f/MAX10_JTAG_Secure_Unlock_UG.pdf
