16 years ago
How would you create infinite simulation loop in modelsim using erilog/ vhdl
Any ideas, hints would be helpful.
    You could just post your homework assignment for us. :)
    You could create a task that contains your loop. Then just schedule the task to run at some predefined interval.
    Jake
    Hi Jakob,
    I wish this was only an assignment :)
    I do thank you though and if you do have any other suggestions please do let me know.
    thanks
    I presume you are aware of the $stop and $finish directives in verilog?
    Descriptions from the sutherland HDL reference:
    $finish;
    Finishes a simulation and exits the simulation process.
    $stop;
    Halts a simulation and enters an interactive debug mode.
    Jake
    This should make modelsim get stuck in an infinite loop in VHDL:
    signal a : std_logic := '1';
    signal b : std_logic := '0';
    b <= a and not b;
    thanks tricky... did end up doing something like that. general question can anyone give me an example how do i make 2 always loops to be continuously switching between each other
    you can try
    process
    begin
    loop
    wait until clk='1';
    end loop;
    end process;
    Did I conceive a circuit under quartusII and do I want validated it by a file of data to elaborate by a program in C language, and to recover the exits as a file text, how to make?
