15 years ago
How to use SDRAM on de2-70 board?
Hi everyone.
I'm newbie about Quartus II & Nios II, and using Altera DE2-70 board.
I have two questions about SDRAM on DE2-70.
1. I don't want to use neither the SOPC builder nor the NIOS 2 processor.
In other words, I don't want to use SDRAM controller, C++ software.
I want to use only verilog code and read/write data from/to SDRAM address directily.
I need to know how to read/write 16 bits word from/to an address location of the SDRAM, lets say 0x000000.
and, do I need to concern about the refreshing time, precharge, ... etc?
2. If I have to use the SOPC builder & the NIOS 2 processor for SDRAM controller to use read/write data from/to SDRAM address,
how can I know SDRAM address about data in/out, and how can I express c or c++ code about read/write data from/to SDRAM address?
please let me know the solution or send me very simple source about sdram data & address using NIOS II/e cpu, JTAG UART, SDRAM..
thank you very much in advance.
    --- Quote Start ---
    > 1. before I follow the chapter 5, do i have to fpga pin assignment & sof download?
    yes you do.
    but I think you already have assigned project with the development board.
    if you have one, you don't have to assign the pins.
    but yes,you need sof download.
    > 2. in chapter 5, I don't understand customAddress variable.
    > I can't find customAddress variable in verilog hdl source.
    the customAddress means "base address" in SOPC builder.( see figure 14)
    so you simply replace "0x00000000" into the address you got in SOPC builder.
    all right, I will prepare next stage in next morning (morning for me).
    see you.
    --- Quote End ---
    thank you for your kindness.
    I followed your instruction, and I made sopc verilog source code like this.
    module SampleIP(iKEY, iCLK_50, oLEDG, coe_out);
    input [0:0] iKEY;
    input iCLK_50;
    output [7:0] oLEDG;
    output [31:0] coe_out;
    ex1_SampleIP u_ex1_SampleIP
    .clk_0 (iCLK_50),
    .coe_out_from_the_mysampleip_0 (coe_out_from_the_mysampleip_0),
    .out_port_from_the_led_pio (oLEDG),
    .reset_n (iKEY)
    Q> I have a pin map of development board as you said, and
    I make top-level entity code for connection fpga board & sopc module
    by using ex1_SampleIP_inst.v code.
    What is the purpose of using LED?
    And iCLK_50, iKEY, oLEDG are already assigned in pin map,
    but, I don't know where ".coe_out_from_the_mySampleIP_0" is connected.
    Do I have to connect from coe_out to LED for checking coe_out by using LED out?
    just quick reply.
    you don't have to connect to the LEDs, but if you connect to LEDs
    instead of "out_port_from_the_led_pio".
    you can control LED from NiosII.
    if you send a value like 0x01 via NiosII ( refer to address from SOPC )
    you can lite one of led on the board.
    but you don't have to connect to the LEDs.
    just leave them and set a value to the address( of your IP-core )
    and read it as I told you in the document.
    you can read the value. which means your value is saved on the register of your own IP.
    all right, I will write next document for your next step.
    hi, there.
    I wrote a document which describes how to access Avalon-Bus in HDL.
    http://www.akiron.com/fpga/customipmaster.pdf
    here you can see the document.
    next step, I will tell you how to read/write memories with using burst transfer.
    next step is final step of your question.
    have a nice day.
    --- Quote Start ---
    hi, there.
    have a nice day.
    --- Quote End ---
    Hi.
    I followed your first instruction, and I have the result as you said.
    I am trying to do your second instruction, and I have some questions again..
    1. Why do I have to use cpuclock, sdramclock?
    Why are they separated from mainclock(50Mhz)?
    (I don't know the reason about 3 clocks)
    And I can't setup Timer, DLL, so I tried to study about that.
    2. What's the difference with Avalon-Master and Avalon-Slave?
    (I don't know what's the Avalon)..
    and Why do I use Custom-IP Ram?
    Can I just use SDRAM or On-chip Memory for data in/out from ram address?
    For example, can I use only SDRAM address(0x00800000 in your second instruction) instead of Custom-IP & On-chip Memory address(0x00002000
    & 0x00002010) in 11 page of second instruction?
    Thanks for your very kind help.
    no you don't.
    you don't have to multiple clocks.
    the reason why SOPC builder could have multiple clock is...
    cpu needs stable clock.
    sdram needs first clock and shifted clock.
    but you don't have to care about that. unless it gets problem.
    you just use the clock which examples prepared.
    Avalon is a name.
    muster requests read and write like NiosII does.
    slave answer the requests of master.
    it means first document?
    this is a step one.
    when you finish the document.
    you know what Custom-IP is, don't you?
    this is a practice.
    hum.
    indeed.
    you can access to the SDRAM exactly same way, instead of on-chip RAM.
    but your SDRAM might have your NiosII program.
    I don't know which address is safe( you have to find way by your self).
    you need to mind that this is a practice.
    I'm teaching foundation of customIP such as Avalon-MM Master / Avalon-MM Slave.
    after that, you have to lean how to attach the idea on your system by yourself.( <- cases are always different )
    anyway, I will write last document.
    but I'm not sure if I can finish that by this weekend.
    see you later by then.
    teddy80.
    I need one or two days to finish the next document.
    sorry.
    Hi everyone,
    I would like to ask any idea how to transfer data from verilog to NiosII for processing and transfer back to verilog again? Recently, I work on video processing project, the data is from the TV decoder (after converting to RGB/gray scale), required to transfer it to NiosII for processing. After processing is finished, the data is again transferred back to verilog for VGA display. Anyone can show me some simple example design how to transfer data to NiosII and transfer back to verilog by using avalon bus? Thanks a lot and I will appreciate it.
    Best regard,
    TWK
    Hello teddy,
    Were you able to get Altera's SDRAM controller IP to work without NIOSII for your project? I've been trying to get it to work for a while without any luck.
