15 years agojust quick reply.
> Do I have to connect from coe_out to LED for checking coe_out by using LED out? you don't have to connect to the LEDs, but if you connect to LEDs instead of "out_port_from_the_led_pio". you can control LED from NiosII. if you send a value like 0x01 via NiosII ( refer to address from SOPC ) you can lite one of led on the board. but you don't have to connect to the LEDs. just leave them and set a value to the address( of your IP-core ) and read it as I told you in the document. you can read the value. which means your value is saved on the register of your own IP. all right, I will write next document for your next step.
