wa_itd
4 months agoHow to specify the library for files in the Component Editor?
I am making a custom IP component in Quartus Prime 26.1. Most files are simply part of the "work" library, however there is at least one file which needs to be compiled under a specific library name...
- 4 months ago
Inside IP, you can only use work. Or move that file out of the IP to use mylib
wa_itd
4 months agoThank you, however my custom component, when instantiated in Platform Designer, is an IP core. So, I think I am unable to change the library for individual files within an IP core (but I can change the library which the entire IP core is compiled into).
So I might have to think of some kind of workaround.
ShengN_altera
4 months agochange library "mylib" to "work" ?
- wa_itd4 months ago
So in other words, ditch the library and just use "work" ? This is what I was trying to avoid, but if it is simply not possible in Quartus, then I'll have no other option.
- ShengN_altera4 months ago
