13 years agoHow to see the critical path of the design?
After the design is fully compiled, there is a parameter in different corner mode that is fmax. As my understand, this value depends on the length of critical path in the design. If the critical path is too long, where there are too many logic between two registers, the fmax will be low. I don't know whether my understanding is right. If it is, how can I check the critical path of the design and try to shorten it? If it isn't, anybody can explain and usually how to increase the fmax?
Why in fast 1200Mv 0c model, there is not Fmax report? Thanks very much.
