13 years ago --- Quote Start --- You should use Timequest to find this information. Specify your timing requirements and which clock frequencies you must use in your design, and any path that is too long to fit your requirements will end up in the "Top failing paths" report. AFAIK Timequest gives a Fmax for all 3 timing models used. --- Quote End --- Thanks. I got it. Sometimes, when I read the fmax, the report posts several clocks in my design with different fmax. What is mean of that?
