Altera_ForumHonored Contributor13 years agoHow to see the critical path of the design? After the design is fully compiled, there is a parameter in different corner mode that is fmax. As my understand, this value depends on the length of critical path in the design. If the critical path...Show More
Altera_ForumHonored Contributor13 years ago --- Quote Start --- Just look at slack figures. The smallest slack is the critical path. --- Quote End --- Thanks very much, kaz.
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
