18 years agoHow to reference hierarchy nodes in QII using Verilog
I'm trying to keep redudant logic. Obviously, simply setting "remove redudant logic" off doesn't work. So instead, I want to try to access the outputs from multiple instances of the redudant logic, and just make a dummy output purely to keep the optimization out of the way. Here is what I did:
parameter NUM_OF_DANGLING_LOADS=5; dff1 dummy_reg[NUM_OF_DANGLING_LOADS-1:0](.d(reg1out), .q(dummy_out), .clk(clock), .reset(dummy_reset)); initial begin for (i=0; i<NUM_OF_DANGLING_LOADS; i=i+1) and and2(dummy_out, dummy_reg[i].q, dummy_out); end QII compiler Error (10207): Verilog HDL error: can't resolve reference to object "q" However, in QII help, it states that it supports hierarchical names: "Hierarchical Names Supported. No references to objects outside the current module or to objects in a generate-for hierarchy." It's not the for loop that caused the error. I tried this and it didn't work either: dff reg1(.d(datain), .q(reg1out), .clk(clock)); assign dummy_out = reg1.q; Same error. Anyone knows how to reference hierarchy nodes in QII using Verilog?
