18 years agoAlso turn off remove duplicate registers. If that doesn't do it, it's probably due to something else. And if you have the same logic written twice, why do you want it kept? (They're can be fanout-distance issues, but that's for closing timing, which adding logic structures too isn't going to help.)
You don't reference the .q, you use the signal already hooked up to it, dummy_out[i].
