TuckerZ's avatar
TuckerZ
3 years ago
How to instantiate components of Cyclone V IOE for design.
I am trying to instantiate the DDR and read FIFO items that are integrated into the Cyclone V I/O elements (IOEs). I know you can instantiate DDR registers using the ALTDDIO IP. However, I have not been able to find any way to instantiate the READ FIFO that is attached to the output of the DDR registers. How can I instantiate the Read FIFO?
This is an image from the Cyclone V's Volume 1 User Guide: Device Integration and Interfaces. you can see at the bottom is the DDR registers and attached to the output is a block labeled "Read FIFO".
Thank you,
Tucker Z
  • Structures like that are usually added as needed based on the design. If you add a FIFO IP and connect it to an I/O or use an IP that has a parameter for using the FIFO, the synthesized design would make use of that hardware. There's no specific IP as far as I know to implement that particular FIFO.
  • sstrell's avatar
    sstrell
    • TuckerZ's avatar
      TuckerZ
      So they only way to use that FIFO is to have the software infer its usage?
  • SyafieqS's avatar
    SyafieqS
    Hi Tucker,
    This is true as mentioned by sstrell. In this case place and route engine will automatically choose the resources needed to implement a design. But to implement the fifo read to output of DDR, I am checking if that is possible or not by manually instantiating it.
  • sstrell's avatar
    sstrell
    Don't know. Like I said, it's possible a particular IP might have an option you could set to enable its use, but the whole point of a place and route engine is to automatically choose the resources needed to implement a design.
    • TuckerZ's avatar
      TuckerZ
      Perhaps someone at Intel can shed some more light on this.
