TuckerZ
3 years agoHow to instantiate components of Cyclone V IOE for design.
Hello, I am trying to instantiate the DDR and read FIFO items that are integrated into the Cyclone V I/O elements (IOEs). I know you can instantiate DDR registers using the ALTDDIO IP. However, I h...
- 3 years ago
Structures like that are usually added as needed based on the design. If you add a FIFO IP and connect it to an I/O or use an IP that has a parameter for using the FIFO, the synthesized design would make use of that hardware. There's no specific IP as far as I know to implement that particular FIFO.
SyafieqS
3 years agoHi Tucker,
This is true as mentioned by sstrell. In this case place and route engine will automatically choose the resources needed to implement a design. But to implement the fifo read to output of DDR, I am checking if that is possible or not by manually instantiating it.
