How to implement basic read write operation in UFM onchip flash IP (Non-volatile memory)
How to implement basic read write operation in UFM onchip flash IP (Non-volatile memory) in 10M16 FPGA in Quartus prime 17.0.
https://community.intel.com/t5/Programmable-Devices/MAX10-UFM-Read-Operation/m-p/194877
I am facing the same error as her and need on urget basis.
Shweta Sawant
- Farabi_Altera
Please refer to design example here: https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset03/max10ufm-write-operation-ug.pdf
regards,
Farabi
- Shweta_sawant
We are facing the same problem as the link mentioned in the above question.
We need it on urgent basis. Facing error in particularly read operation (read_valid signal not updating from onchip_flash IP).Thankyou for your time.
Shweta Sawant
- Shweta_sawant
As per the document mentioned in the answer above, we developed the code as below. But, we are facing issue in tehe read operation.
Codelibrary ieee;use ieee.numeric_std.all;use IEEE.STD_LOGIC_UNSIGNED.ALL;use ieee.std_logic_1164.all;entity NVM_Read_write isport(clock_20mhz_i : in std_logic;reset_ni : in std_logic;csr_readdata_i : in STD_LOGIC_VECTOR(31 DOWNTO 0);waitrequest_i : in STD_LOGIC;readvalid_i : in STD_LOGIC;en_read_i : in STD_LOGIC;en_write_i : in STD_LOGIC;csr_addr_o : OUT STD_LOGIC;csr_writedata_o : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);csr_write_o : OUT STD_LOGIC;csr_read_o : OUT STD_LOGIC;data_addr_o : OUT STD_LOGIC_VECTOR(12 DOWNTO 0);data_writedata_o : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);data_write_o : OUT STD_LOGIC;data_read_o : OUT STD_LOGIC;readvalid_counter_o : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);burstcount_o : OUT STD_LOGIC_VECTOR(3 DOWNTO 0));end entity;architecture arch of NVM_Read_write is--type STATES is (STATE_RESET, STATE_DISABLE_WP, STATE_WR_DATA, STATE_WR_WAITREQ, STATE_CHK_STATUS, STATE_EN_WP,-- STATE_RD_DATA, STATE_RD_WAITREQ, STATE_RD_WAIT_RDVALID_HIGH, STATE_RD_WAIT_FINISH, STATE_INC_ADDR,-- STATE_STOP_RD);--signal STATE ,NEXT_STATE : STATES;SIGNAL STATE_s : STD_LOGIC_VECTOR(3 DOWNTO 0);SIGNAL NEXT_STATE_s : STD_LOGIC_VECTOR(3 DOWNTO 0);SIGNAL addr_counter_s : unsigned(31 DOWNTO 0);SIGNAL data_addr_s : STD_LOGIC_VECTOR(12 DOWNTO 0);SIGNAL readvalid_counter_s : STD_LOGIC_VECTOR(3 DOWNTO 0);CONSTANT STATE_RESET_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0000"; -- ResetCONSTANT STATE_DISABLE_WP_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0001"; -- Disable write protectionCONSTANT STATE_WR_DATA_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0010"; -- write data up to address#256CONSTANT STATE_WR_WAITREQ_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0011"; -- increase the address counter only when waitrequest goes lowCONSTANT STATE_CHK_STATUS_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0100"; -- check status register to confirm write is successfulCONSTANT STATE_EN_WP_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0101"; -- enable back write protectionCONSTANT STATE_RD_DATA_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0110"; -- read dataCONSTANT STATE_RD_WAITREQ_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "0111"; -- if waitrequest goes high, check readvalid signalCONSTANT STATE_RD_WAIT_RDVALID_HIGH_c: STD_LOGIC_VECTOR(3 DOWNTO 0) := "1000"; -- if readvalid signal goes high, check readvalid counterCONSTANT STATE_RD_WAIT_FINISH_c: STD_LOGIC_VECTOR(3 DOWNTO 0) := "1001"; -- check if readvalid counter reached 8CONSTANT STATE_INC_ADDR_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "1010"; -- increase the addrress by 8 since the burstcount is set to 8 for burst readCONSTANT STATE_STOP_RD_c : STD_LOGIC_VECTOR(3 DOWNTO 0) := "1011"; -- stop reading if addrress reach 256begindata_addr_o<= data_addr_s;readvalid_counter_o<= readvalid_counter_s;process (reset_ni, clock_20mhz_i) isbeginif reset_ni='0' thenSTATE_s <= STATE_RESET_c;elsif rising_edge(clock_20mhz_i) thenSTATE_s <= NEXT_STATE_s;end if;end process;process (reset_ni, clock_20mhz_i) isbeginif reset_ni='0' thendata_addr_s <= (others =>'0');addr_counter_s <= (others =>'0');csr_addr_o <= '0';csr_write_o <= '0';csr_writedata_o <= x"FFFFFFFF";burstcount_o <= "0000";elsif rising_edge(clock_20mhz_i) thencase STATE_s isWhen STATE_RESET_c =>data_addr_s <= (others =>'0');addr_counter_s <= (others =>'0');csr_addr_o <= '0';csr_write_o <= '0';csr_writedata_o <= x"FFFFFFFF";burstcount_o <= "0000";data_write_o <= '0';data_read_o <= '0';When STATE_DISABLE_WP_c =>csr_addr_o <= '1';csr_write_o <= '1';csr_writedata_o <= x"FC7FFFFF";burstcount_o <= "0001";When STATE_WR_DATA_c =>csr_addr_o <= '0';csr_write_o <= '0';csr_writedata_o <= x"FFFFFFFF";data_addr_s <= std_logic_vector(unsigned(addr_counter_s(12 downto 0)));data_write_o <= '1';data_writedata_o <= std_logic_vector(unsigned(addr_counter_s));When STATE_WR_WAITREQ_c =>if waitrequest_i ='0' thenaddr_counter_s <= addr_counter_s + 1;data_write_o <= '0';end if;When STATE_CHK_STATUS_c =>data_write_o <= '0';csr_addr_o <= '0';csr_read_o <= '1';When STATE_EN_WP_c =>csr_addr_o <= '1';csr_write_o <= '1';csr_writedata_o <= x"FFFFFFFF";data_addr_s <= "0000000000000";When STATE_RD_DATA_c =>data_read_o <= '1';burstcount_o <= "1000";When STATE_RD_WAITREQ_c =>When STATE_RD_WAIT_RDVALID_HIGH_c =>data_read_o <= '0';When STATE_RD_WAIT_FINISH_c =>When STATE_INC_ADDR_c =>data_addr_s <= data_addr_s + "0000000001000";When STATE_STOP_RD_c =>data_read_o <= '0';data_addr_s <= (others => '0');when others =>NULL;end case;end if;end process;process (en_read_i,en_write_i) isbeginif (en_read_i='0') and (en_write_i='0') thenNEXT_STATE_s <= STATE_RESET_c;elsecase STATE_s isWhen STATE_RESET_c =>if en_write_i ='1' thenNEXT_STATE_s <= STATE_DISABLE_WP_c;elseif en_read_i='1' thenNEXT_STATE_s <= STATE_RD_DATA_c;elseNEXT_STATE_s <= STATE_RESET_c;end if;end if;When STATE_DISABLE_WP_c =>NEXT_STATE_s <= STATE_WR_DATA_c ;When STATE_WR_DATA_c =>NEXT_STATE_s <= STATE_WR_WAITREQ_c;When STATE_WR_WAITREQ_c =>if waitrequest_i = '0' thenif addr_counter_s < x"00000100" thenNEXT_STATE_s <= STATE_WR_DATA_c;elseNEXT_STATE_s <= STATE_CHK_STATUS_c;end if;elseNEXT_STATE_s <= STATE_WR_WAITREQ_c;end if;When STATE_CHK_STATUS_c =>NEXT_STATE_s <= STATE_EN_WP_c;When STATE_EN_WP_c =>if csr_readdata_i(3) = '1' thenNEXT_STATE_s <= STATE_RESET_c;elseNEXT_STATE_s <= STATE_EN_WP_c;end if;When STATE_RD_DATA_c =>if data_addr_s <= "0000100000000" thenNEXT_STATE_s <= STATE_RD_WAITREQ_c;elseNEXT_STATE_s <= STATE_STOP_RD_c;end if;When STATE_RD_WAITREQ_c =>if waitrequest_i = '1' thenNEXT_STATE_s <= STATE_RD_WAIT_RDVALID_HIGH_c;elseNEXT_STATE_s <= STATE_RD_WAITREQ_c;end if;When STATE_RD_WAIT_RDVALID_HIGH_c =>if readvalid_i = '1' thenNEXT_STATE_s <= STATE_RD_WAIT_FINISH_c;elseNEXT_STATE_s <= STATE_RD_WAIT_RDVALID_HIGH_c;end if;When STATE_RD_WAIT_FINISH_c =>if readvalid_counter_s = "1000" thenNEXT_STATE_s <= STATE_INC_ADDR_c;elseNEXT_STATE_s <= STATE_RD_WAIT_FINISH_c;end if;When STATE_INC_ADDR_c =>NEXT_STATE_s <= STATE_RD_DATA_c;When STATE_STOP_RD_c =>NEXT_STATE_s <= STATE_STOP_RD_c;when others =>NULL;end case;end if;end process;process (clock_20mhz_i ) isbeginif rising_edge(clock_20mhz_i ) thenif en_read_i ='0' thenreadvalid_counter_s <= "0000";elsif en_read_i ='1' thenif readvalid_i = '1' thenreadvalid_counter_s <= readvalid_counter_s + "0001";elsif readvalid_counter_s = "1000" then ---hex8readvalid_counter_s <= "0000";end if;end if;end if;end process;end architecture; - FakhrulA_altera
Hi Shweta_sawant,
Could you specify the error encountered? If available, please provide any error codes or numbers, and consider sharing a screenshot for better assistance. Kindly refer to the instructions in sub-topic 4.2.6, "UFM Read Operation," on page 16 of the Intel® MAX® 10 User Flash Memory User Guide
Fakhrul
- Shweta_sawant
selected signal are not available from ON chip flash IP.
- FakhrulA_altera
Hi Shweta_sawant,
Could you send us with full design as we may need to try to replicate it on our side to further debug the issue.
Fakhrul
- Shweta_sawant
We are not able to get avmm_data_readvalid_i and avmm_data_waitrequest_i as 1 even after the avmm_data_readata is being updated by the memory.
- Shweta_sawant
- FakhrulA_altera
Hi Shweta_sawant,
Just would like to check whether have you go to Tools -> In-System Sources and Probes Editor and toggle the Index S[0] to start?
Fakhrul
- FakhrulA_altera
Since we haven't heard back from you about our previous message, we'll now move this discussion to community support. Feel free to start a new thread for any new questions or issues you have – our Intel experts will be there to help. But if you don't have more questions, the community users can still assist you here. Thanks for your understanding.
