How to fix the timing violation with an IP (altera_mult_add)
The timing violation is present within the multiplier
-ve slack => -2.335
From node
mult_2_64x8:lsm_mult3_inst|lsm_mult_2_64x8_0002:mult_2_64x8_inst|altera_mult_add:altera_mult_add_component|altera_mult_add_n5qg:auto_generated|altera_mult_add_rtl:altera_mult_add_rtl1|ama_data_split_reg_ext_function:datab_split|ama_latency_function:data0_pipeline_reg_block|data_out_array[1][0]~_Duplicate_1
To Node
mult_2_64x8:lsm_mult3_inst|mult_2_64x8_0002:mult_2_64x8_inst|altera_mult_add:altera_mult_add_component|altera_mult_add_n5qg:auto_generated|altera_mult_add_rtl:altera_mult_add_rtl1|ama_register_function:output_reg_block|data_out_wire[41]
Thanks in advance!
- KhaiChein_Y_Intel
Can you share the design.qar for investigation? What is the software edition (Standard/Pro) and version you are using?
KhaiY
- SKGR0
Hi
Version used - Quartus II Standard 16.1.203
I might not be able to share .qar file
Sahana
- KhaiChein_Y_Intel
Hi Sahana,
I have sent you an email for private discussion. Let me know if you do not receive.
KhaiY
- KhaiChein_Y_Intel
Hi Sahana,
May I know if you have any udpates?
KhaiY
- KhaiChein_Y_Intel
Hi Sahana,
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
KhaiY
- SKGR0
Sorry for the delay
The problem is design file cannot be shared.
I would like to receive inputs on how to solve timing issues on irrelevant paths in the system.
I figured out that the problem was not present in the path that is traceable in the design.
System is something like this
a-> b-> c ->d
where a,b,c,d are modules which work in sequence
The timing issue is in
from node : module d
to node : module b
(there is not link between these modules in the design)
SKGR0
- KhaiChein_Y_Intel
Hi SKGR0,
If there is no timing relationship between the two module or irrelevant path, is it possible to false path ?
KhaiY
- SKGR0
Hi
Set as False path
I have tried this .
The process is tedious as the SDC has to be updated and the compilation has to be repeated for more number of iterations (time consuming) to achieve frequency.
Is there an alternate way?
SKGR0
- KhaiChein_Y_Intel
If you set false path to the irrelevant path, you will not see the timing analysis on the path and there should be only one time compilation. Do you still see the timing analysis on the same path after you apply false path?
KhaiY
- SKGR0
Hi KhaiY
Yes ..i do observe that...
I want to add another point.
I see that one lpm_divide instance used in the design consumes 6k MLAB
And though the timing path is irrelevant , the "to node" points to this divider.
Is there a way i can make the lpm_divide instance (63x63) be forced to implement using M10Ks ?
Will this help in improving the timing?
SKGR0
- KhaiChein_Y_Intel
Hi SKGR0,
What is the device you are using? It is difficult to fix timing violation without looking into the design. Kindly provide a design.qar or test case that can reproduce the error.
KhaiY
- KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
