SKGR0
6 years agoHow to fix the timing violation with an IP (altera_mult_add)
The timing violation is present within the multiplier -ve slack => -2.335 From node mult_2_64x8:lsm_mult3_inst|lsm_mult_2_64x8_0002:mult_2_64x8_inst|altera_mult_add:altera_mult_add_component|alte...
KhaiChein_Y_Intel
6 years agoHi SKGR0,
If there is no timing relationship between the two module or irrelevant path, is it possible to false path ?
KhaiY
SKGR0
6 years agoHi
Set as False path
I have tried this .
The process is tedious as the SDC has to be updated and the compilation has to be repeated for more number of iterations (time consuming) to achieve frequency.
Is there an alternate way?
SKGR0
