SKGR0
6 years agoHow to fix the timing violation with an IP (altera_mult_add)
The timing violation is present within the multiplier -ve slack => -2.335 From node mult_2_64x8:lsm_mult3_inst|lsm_mult_2_64x8_0002:mult_2_64x8_inst|altera_mult_add:altera_mult_add_component|alte...
KhaiChein_Y_Intel
6 years agoHi,
If you set false path to the irrelevant path, you will not see the timing analysis on the path and there should be only one time compilation. Do you still see the timing analysis on the same path after you apply false path?
KhaiY
