How to fix the timing violation with an IP (altera_mult_add)
Hi Sahana,
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
KhaiY
Sorry for the delay
The problem is design file cannot be shared.
I would like to receive inputs on how to solve timing issues on irrelevant paths in the system.
I figured out that the problem was not present in the path that is traceable in the design.
System is something like this
a-> b-> c ->d
where a,b,c,d are modules which work in sequence
The timing issue is in
from node : module d
to node : module b
(there is not link between these modules in the design)
SKGR0
