14 years agoHow to find Fmax of my design??
please i am really need your help.
i did the follwoing vhdl design: library ieee; use ieee.std_logic_unsigned.all; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity test is port( clk : in std_logic; rst : in std_logic; input : in std_logic_vector (7 downto 0); output : out std_logic_vector (7 downto 0)); end entity test; architecture kkk of test is signal x0 , x1 , x2 , x3 , x4 , x5 , x6 , x7 : std_logic; begin output <= x7 & x6 & x5 & x4 & x3 & x2 & x1 & x0 ; process (clk,rst) begin if (rst='1') then x0 <= '0'; x1 <= '0'; x2 <= '0'; x3 <= '0'; x4 <= '0'; x5 <= '0'; x6 <= '0'; x7 <= '0'; elsif (clk'event and clk='1') then x0 <= input(7) AND input(6) AND input(4) AND input(3) AND input(1) AND input(0) ; x1 <= input(4) AND input(2) ; x2 <= input(5) AND input(0) ; x3 <= input(4) AND input(2) ; x4 <= input(7) AND input(5) ; x5 <= input(7) AND input(5) AND input(4) AND input(1) ; x6 <= input(5) AND input(3) AND input(0) ; x7 <= input(5) AND input(3) AND input(1) AND input(0) ; end if; end process; end architecture kkk; i am using quartus ii web edition 8.1, i couldn't find the max frequency of the design. i got the following: Info: No valid register-to-register data paths exist for clock "clk" Info: tsu for register "x0" (data pin = "input[7]", clock pin = "clk") is 5.000 ns Info: tco from clock "clk" to destination pin "output[0]" through register "x0" is 8.800 ns Info: th for register "x1" (data pin = "input[2]", clock pin = "clk") is -0.700 ns Info: Quartus II Classic Timing Analyzer was successful. 0 errors, 1 warning Info: Quartus II Full Compilation was successful. 0 errors, 2 warnings i know the report talking about no valid register-to-register.......
i just want to get the value of (output) every clock cycle! the timing analyzing summery as follow: Type Slack Required Time ActualTime From To From Clock To Clock Worst-case tsu N/A None 5.000 ns input[7] x0 -- clk Worst-case tco N/A None 8.800 ns x0 output[0] clk -- Worst-case th N/A None -0.700 ns input[6] x0 -- clk Total number of failed paths Do I must change the design to get Fmax? if yes, that will be little strange for me since the design is working perfectly! thanks in advance.
