How do I do line by line timing analysis in Quartus Prime Timing Analyzer?
- 2 years ago
I understood your intention however I don't think Quartus able to do that. In Quartus failing path only shown in STA report as it is, If you need the path b/w of the failing, (seem like a chain path of that node). you probably need to manually report timing (playing with from/to of intention node to manually compare it which I think bit tedious).
Let me know if there is any concern.
Finding paths in the timing analyzer doesn't really work like that. All timing paths are register (or input) to register (or output). As such, you'd want to look for the timing paths between the sources of those signals and the output port or register. The Data Arrival timing section of a report generated from "Report Timing" with the full detail option selected breaks down the incremental delays through combinational logic, which sounds like what you are looking for.
You could also open the RTL Viewer or Technology Map Viewer, find the paths you want to analyze, and right-click them to cross-probe to the timing analyzer and generate the reports for the paths you need.
- Pack_of_lone_wolves2 years ago
@sstrell wrote:You could also open the RTL Viewer or Technology Map Viewer, find the paths you want to analyze, and right-click them to cross-probe to the timing analyzer and generate the reports for the paths you need.
I'd exactly want to do that, let me try and confirm if I'm able to do this exact thing. (I regret my late reply)
