by the way, I turned "Assignments->settings->Analysis & Synthesis Settings->more settings->auto ram replacement" option on,but it seems no use~
Also, I don't want to achieve it by creating new megafunction!
Lots of info on this subject here http://www.altera.com/literature/hb/qts/qts_qii51007.pdf Quartus will only infer a RAM if it is actually implementable in internal RAM. i.e. it must be synchonous and adhere to various rules. Check out the code samples in the above doc - Altera_Forum
Thank you! I will try it.
I'm also a fan of the Templates in Quartus. With your HDL open, go to Edit -> Template -> VHDL and there are a couple RAM/ROM examples. You can paste them directly into your code.
I'm sorry! But I can't find "Template" in the "Edit" menu , also the focus on the VHDL file.
Indeed! I do not want just to achieve MEMORY,I just want Quartus to compilate my code to use the momory internal. It seems that I only achieve it by creating new megafunction. Thank you all the time! - Altera_Forum
The Edit menu is context sensitive, so it will only be there if you have a VHDL file open in the main window. If you're looking at a compilation report or something like that it won't be there. (Or you're using an older version of Quartus, but I'm pretty sure these are at least a year or two old). And using the code from the referenced manual will also work.
Thank you Rycs!
Thank you vernmid! This way seems no way! I decide to achieve it by creating new megafunction. - Altera_Forum
Quartus language templates have been introduced with Quartus V7.1, I think. Code examples or also shown in the Quartus Handbook in the recoomend hdl coding styles chapter.
Hi ! That may be the problem , the version I used is V6.1 .
Thank you!
