Altera_ForumHonored Contributor17 years agoHow can I make the compilation to achieve MEMORY using RAM but not LEs? Hello everyone! I write the program to achieve RAM like this: TYPE MEMORY IS ARRAY (0 TO 127) OF std_logic_vector(15 DOWNTO 0); SIGNAL RAM_DATA : MEMORY; When the Quartus ...Show More
Altera_ForumHonored Contributor17 years agoHi ! That may be the problem , the version I used is V6.1 . Thank you!
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorConnection bit order between hierarchyCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
