12 years ago
How about a verilog case statement that covers a range?
e.g. :
case(xcount) begin
1-100 : junk<=1;
101 : junk<=2;
102-200 : junk<=3;
endcase
    SystemVerilog has it using the inside operator
    case (xcount) inside
       : junk<=1;
      101 : junk<=2;
       : junk<=3;
    endcase
    Another nice thing about the case inside statement is that it uses asymmetric wildcard matching.
    case (xcode) inside
      3'b00? : junk<=1;
      3'b0?0 : junk<=2;
      3'b?00 : junk<=3;
      default: junk <='x;
    endcase
    That means don't cares only match on the case item, not the selecting expression. So if xcode == 3'bx01, the default branch would be taken, not the first branch.
    --- Quote Start ---
       : junk<=1;
      101 : junk<=2;
       : junk<=3;
    endcase
    case (xcode) inside
      3'b00? : junk<=1;
      3'b0?0 : junk<=2;
      3'b?00 : junk<=3;
      default: junk <='x;
    endcase
    --- Quote End ---
    Thanks very much. But I think this "inside" only for SystemVerilog, right?
    Yes. Hopefully if more people ask for it, it will become more widely supported.
    To code this in Verilog, you could create an in-between function or macro
    function reg inbetween(input  low, value, high);
    begin
      inbetween = value >= low && value <= high;
    end
    endfunction
    case (1);
      inbetween(1,xcount,100): junk<=1;
      inbetween(101,xcount,101): junk<=2;
      inbetween(102,xcount,200): junk<=3;
    endcase
    --- Quote Start ---
    begin
    end
    endfunction
    case (1);
    endcase
    --- Quote End ---
    Thanks dave. Yes, I think this is very good idea. And this should be able to be synthesized, right?
    --- Quote Start ---
       : junk<=1;
      101 : junk<=2;
       : junk<=3;
    endcase
    case (xcode) inside
      3'b00? : junk<=1;
      3'b0?0 : junk<=2;
      3'b?00 : junk<=3;
      default: junk <='x;
    endcase
    --- Quote End ---
    I added this syntax to an existing SystemVerilog design, but Quartus choked on the "inside" keyword when I tried to build. It's a little ironic, because the Quartus text editor recognizes it as a key word (it shows up in blue). Am I correct in saying that Quartus does not support "case inside"? I do not see it mentioned in the Quartus SV Support documentation.
    It is very easy to recognize a list of keywords to prevent people from using them as identifiers. Supporting the functionality behind them is another story.
