12 years ago --- Quote Start --- SystemVerilog has it using the inside operator
case (xcount) inside
: junk<=1;
101 : junk<=2;
: junk<=3;
endcase Another nice thing about the case inside statement is that it uses asymmetric wildcard matching. case (xcode) inside
3'b00? : junk<=1;
3'b0?0 : junk<=2;
3'b?00 : junk<=3;
default: junk <='x;
endcase That means don't cares only match on the case item, not the selecting expression. So if xcode == 3'bx01, the default branch would be taken, not the first branch. --- Quote End --- I added this syntax to an existing SystemVerilog design, but Quartus choked on the "inside" keyword when I tried to build. It's a little ironic, because the Quartus text editor recognizes it as a key word (it shows up in blue). Am I correct in saying that Quartus does not support "case inside"? I do not see it mentioned in the Quartus SV Support documentation.
