12 years agoHelp with internal Clock and States
Hi, I am very knew to Verilog and coding in general. I have to build a state machine so that when I have an input, the internal clock doesnt register it more then once. Instead it will pulse an output for one clock cycle. In order to do this I need to implement Input Conditioning. So there will be what I believe to be 5 states.
A: input 0,clock 0 or 1, output 0 B: input 1, clock 0, output 0 C: input 1, clock 1, output 1 D: input 1 or 0, clock 0, output 1 E: input 1 or 0, clock 1, output 0 I wrote some code which I believe is correct. My main area of concern is when I start the second Always block, the clk isn't posedge in the brackets, because the compiler wouldnt let me do it otherwise. The code compiles, but in the simulator there seems to be no change in the output regardles of inputs. module attempt3(clk, a, reset, out); input clk, a, reset; output out; reg out; reg [1:0] state; parameter A=0, B=1, C=2, D=3, E=4; always @(state) begin case (state) A: out = 0; B: out = 0; C: out = 1; D: out = 1; E: out = 0; endcase end always @(a, clk, reset) begin if (reset) state = A; else case (state) A: if (a==0) state = A; else state = B; B: if (a==0) state = A; else if (clk==0) state = B; else state = C; C: if (clk==0) state = D; else state = C; D: if (a==0) state = A; else state = E; E: if (a==0) state = A; else state = E; endcase end endmodule Thanks for any advice!
