Hard reset with USB-Blaster and Quartus
Hello There,
Can you please help me with this issue?
By any chance can I have the access to USB_Blaster drivers to control the TMS pin? Is there any command that I can use. I see even with Quartus Prime Standard version (GUI application), I am not able to reset the TAP-State.
Awaiting the response from your end.
BR,
Alkesh
- FakhrulA_altera8 months ago
Hi Alkesh,
A hard reset shouldn’t be required. This usually happens because the JTAG TAP or a device is left in a test state. Between scans, reset the TAP, park all devices in BYPASS, return to Run‑Test/Idle, and do a short DR flush. Avoid ending in EXTEST or HIGHZ. If your device is Stratix 10, enable boundary‑scan once via the MISCCTRL instruction. Quartus Programmer isn’t a full boundary‑scan tester, so you need to manage these states or use a dedicated BST tool.
Reference: Intel MAX 10 JTAG Boundary‑Scan Testing User Guide
Intel® MAX® 10 JTAG Boundary-Scan Testing User Guide
What device you are using btw?
Fakhrul - FakhrulA_altera8 months ago
As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Altera experts. Otherwise, community users will continue to assist you here. Thank you.
