Generated visible in "Report Clocks" but the same generated clock not found during timing analysis
In my design when I report clocks, I see that the the clock in question is generated and the generated clocks are set to be asynchronous by "set_clock_groups -asynchronous ...." in the top level .sdc but during the timing analyzer cannot find those clocks and gives critical warning that the clocks could not be matched with a existing clock which leads to timing violations to be reported.
The relevant snippets are attached.
The .sdc has additional derive_pll_clocks at the beginning of the file but that command is ignored.
Please suggest ways that the timing analyzer can detect the clock and apply the set_clock_group constraint.
BB
- sstrell
Have the .sdc files generated by these IP been added to the project? EMIF usually has its own .sdc that gets added automatically. Have you tried running report_sdc in the timing analyzer to see the actual constraints that are being applied to the design?
- BKB
The SDC's for PLLs and other IPs are also automatically added. As per the "Report SDC File List" the sdc for the clock_control_blocki is added and shown in the list with other sdc file.
But in the list generated by "Report SDC" there is no constraint from the clock_control_block_i and hence the constraint which is trying setting the clock groups asynchronous is ignored.
- sstrell
So in your top-level .sdc (you have one, right?) you should have a create_clock for the reference clock input to the device.
- BKB
Yes, I do have a top-level .sdc. I didn't have create_clock at that level as the IP generating that clocks was already having that in its sdc and the clocks were also visible in the "report clocks" list.
I added the create_clock reference and the messages went away. Thanks for your help SStrell.
Best,
BB
- AdzimZM_Altera
