BKB
2 years agoGenerated visible in "Report Clocks" but the same generated clock not found during timing analysis
Hi, In my design when I report clocks, I see that the the clock in question is generated and the generated clocks are set to be asynchronous by "set_clock_groups -asynchronous ...." in the top leve...
sstrell
2 years agoHave the .sdc files generated by these IP been added to the project? EMIF usually has its own .sdc that gets added automatically. Have you tried running report_sdc in the timing analyzer to see the actual constraints that are being applied to the design?
