BKB
2 years agoGenerated visible in "Report Clocks" but the same generated clock not found during timing analysis
Hi, In my design when I report clocks, I see that the the clock in question is generated and the generated clocks are set to be asynchronous by "set_clock_groups -asynchronous ...." in the top leve...
sstrell
2 years agoSo in your top-level .sdc (you have one, right?) you should have a create_clock for the reference clock input to the device.
