SS5's avatar
SS5
7 years ago
FIFO:How to slow down the clock Frequency from 50 Mhz
once I enable your counter, it is writing at full clock speed to the fifo
once the fifo is full, the counter just continues counting
by the time it start reading and printing the first value to the serial port, the fifo is probably already overflowing, as I did print some hello word message. Printing to the serial port is very slow compared to the counter filling up your fifo, and counter counts at something like 50MHz I guess (?)
* once the fifo starts overflowing, not all counter values will go into the fifo, as it is full, and you're only slowly reading the values from the fifo
  • Just checked that the Avalon FIFO memory could not export the "almost full" signal resulting you could not use it as control signal. It is only accessible through IP API or SW control. So, you have to read it from NIOS and then determine the enable signal from PIO. In schematic, connect the "enable" to both counter and write FIFO. Refer to example code for FIFO control in the UG
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf, 20.5.2
  • SS5's avatar
    SS5
    Thanks for your reply.
    Same thing i have followed.
    Enable signal given from PIO
    connected enable to both counter and write FIFO. In NIOS same data is printing continuously for certain cycles. Please clarify me how to sort it out.
    Design as follows
    Counter Verilog Code
    module Counter(
        input clk,
    	 input enable,
        input reset,
        output reg[31:0] Final_value,
       output  reg trig
        reg[31:0] counter_out;
        reg [7:0] temp=0;
        reg [31:0] counter_result;
        wire temp1;
        wire temp2;
       always@(posedge clk)
       begin
        if(reset)
            begin
            trig<=0;
            temp<=0;
            counter_out<=0;
            end
        else if (enable==1'b1)
            begin
            counter_out<=counter_out+1;
            temp<=temp+1;
            if(temp==25)
                begin
                temp<=0;
                trig<=~trig;
                end
      end
    	 assign temp1=trig;
    	 assign temp2=temp1&&clk;
    	 always@(posedge temp2)
    	 if(reset)
    	    counter_result<=0;
    	  else
    	 begin
            counter_result<=counter_result+1;
         end
      always@(posedge trig)
      if(reset)
           Final_value<=0;
       else
      begin
           Final_value<=counter_result;
      end
    endmodule
    Schematic Design
    NIOS CONSOLE, Same data printing For certain cycles.
  • Have you tried to use and understand the example code and register map given in the FIFO API? What you need to do is
    1) ​Set the almost full threshold using initialization : altera_avalon_fifo_init()
    2) Monitor the read status of FIFO : altera_avalon_fifo_read_status() and its status description can be referred to 20.5.1 Software control=> "i_status"
  • SS5's avatar
    SS5
    Hi
    On-Chip Memory Size is 4096
    FIFO Depth : 1024
    So, have i have set the
     # define ALMOST_EMPTY 1
     # define ALMOST_FULL 1000               //FIFO Depth 1024
    The ALMOSTEMPTY and ALMOSTFULL printed in the console are correct.
    int main()
           	 int result,i=0;
          // 	Reset the FIFO's IRQ History register. *
           	altera_avalon_fifo_clear_event(FIFO_0_IN_CSR_BASE, ALTERA_AVALON_FIFO_EVENT_ALL);
        	  int code = ALTERA_AVALON_FIFO_OK;
        	  code= altera_avalon_fifo_init(FIFO_0_IN_CSR_BASE, 0x3F,ALMOST_EMPTY,ALMOST_FULL);
        	 IOWR(ENABLE_PIO_BASE, 0, 0x1);
        	 printf("STATUS = %u\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,altera_avalon_fifo_read_status));
        	 while(1)
        	 result=altera_avalon_fifo_read_fifo(FIFO_0_OUT_BASE,FIFO_0_IN_CSR_BASE);
         printf("%d\n",result);
    	return 0;
    In NIOS console,
    STATUS =16
    result: 0
    Suggestion Please
  • SS5's avatar
    SS5
    I have attached the Nios Screen-shot.
    I am getting all data "0"
  • printf("STATUS = %u\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,altera_avalon_fifo_read_status));
    T​he fifo status isn't right. You have put the same function into the function argument. Refer to table 206, to read back all of bits, use the following command:
    printf("STATUS = %u\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,altera_avalon_fifo_status_all));
    To debug, please put this status command before starting the transfer and after enabling the transfer.
  • SS5's avatar
    SS5
    init_input_fifo();
        printf("STATUS = %d\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,    altera_avalon_fifo_status_all));
    	level=altera_avalon_fifo_read_level(FIFO_0_IN_CSR_BASE);
    	printf("\nLevel=%u\n",level);
    	if(level !=0)
    	for(i=0;i<=500;i++)
        	        //result[i]=IORD_ALTERA_AVALON_FIFO_DATA(FIFO_0_OUT_BASE);
        	        data[i]=altera_avalon_fifo_read_fifo(FIFO_0_OUT_BASE, FIFO_0_IN_CSR_BASE);
        	    	printf("data=%lu\t",data[i]);
    	printf("\n Full=%d\n", altera_avalon_fifo_read_almostfull(FIFO_0_IN_CSR_BASE));
    	printf("Empty=%d\n",altera_avalon_fifo_read_almostempty(FIFO_0_IN_CSR_BASE));
    Now my code is right.
