SS5
8 years agoFIFO:How to slow down the clock Frequency from 50 Mhz
once I enable your counter, it is writing at full clock speed to the fifo once the fifo is full, the counter just continues counting by the time it start reading and printing the first value to the...
SS5
8 years agoThanks for your reply.
Same thing i have followed.
Enable signal given from PIO
connected enable to both counter and write FIFO. In NIOS same data is printing continuously for certain cycles. Please clarify me how to sort it out.
Design as follows
Counter Verilog Code
module Counter(
input clk,
input enable,
input reset,
output reg[31:0] Final_value,
output reg trig
reg[31:0] counter_out;
reg [7:0] temp=0;
reg [31:0] counter_result;
wire temp1;
wire temp2;
always@(posedge clk)
begin
if(reset)
begin
trig<=0;
temp<=0;
counter_out<=0;
end
else if (enable==1'b1)
begin
counter_out<=counter_out+1;
temp<=temp+1;
if(temp==25)
begin
temp<=0;
trig<=~trig;
end
end
assign temp1=trig;
assign temp2=temp1&&clk;
always@(posedge temp2)
if(reset)
counter_result<=0;
else
begin
counter_result<=counter_result+1;
end
always@(posedge trig)
if(reset)
Final_value<=0;
else
begin
Final_value<=counter_result;
end
endmoduleSchematic Design
NIOS CONSOLE, Same data printing For certain cycles.
