SS5
8 years agoFIFO:How to slow down the clock Frequency from 50 Mhz
once I enable your counter, it is writing at full clock speed to the fifo once the fifo is full, the counter just continues counting by the time it start reading and printing the first value to the...
SS5
8 years agoHi
On-Chip Memory Size is 4096
FIFO Depth : 1024
So, have i have set the
# define ALMOST_EMPTY 1
# define ALMOST_FULL 1000 //FIFO Depth 1024The ALMOSTEMPTY and ALMOSTFULL printed in the console are correct.
int main()
int result,i=0;
// Reset the FIFO's IRQ History register. *
altera_avalon_fifo_clear_event(FIFO_0_IN_CSR_BASE, ALTERA_AVALON_FIFO_EVENT_ALL);
int code = ALTERA_AVALON_FIFO_OK;
code= altera_avalon_fifo_init(FIFO_0_IN_CSR_BASE, 0x3F,ALMOST_EMPTY,ALMOST_FULL);
IOWR(ENABLE_PIO_BASE, 0, 0x1);
printf("STATUS = %u\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,altera_avalon_fifo_read_status));
while(1)
result=altera_avalon_fifo_read_fifo(FIFO_0_OUT_BASE,FIFO_0_IN_CSR_BASE);
printf("%d\n",result);
return 0;
}In NIOS console,
STATUS =16
result: 0
Suggestion Please
