14 years agoError Code: 8 for command
I'm trying to burn the example "count binary" code into CFI flash on the cyclone III starter board. I'm getting the error, "Error code: 8 for command: nios2eds/bin/nios2-flash-programmer "C:/Users/dsmith/Desktop/Projects/Incremental_FPGA/incFPGA_EPCS_Board/flash/incFPGA_EPCS_Board_Prog_cfi_flash_0.flash" --base=0x0 --sidp=0x1011038 --id=0x0 --timestamp=1311008727 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program " Here is my procedure in some detail. I created the Qsys system ( see image "Qsys" ) I generated that system, and placed it in the bdf. I programmed the flash in Quartus II using this quide (http://www.altera.com/literature/ug/ug_ciii_starter_kit.pdf) I then attempted to program the CFI in NIOS II using the provided "count binary" code and got the error above. You can see a screen shot in the file "NIOSIIProg" below. Thanks for your help. alphaOri
