pdewanga's avatar
pdewanga
3 years ago
Doing FLR makes the pcie device hang
I am trying to do initiate Function Level Reset, on Avlaon streaming pcie hard IP, using setpci command and if I try to read the device back using lspci command the device is hang with ff as shown below,
lspci -v -d:11e1
3b:00.0 Co-processor: Intel Corporation Device 11e1 (rev ff) (prog-if ff)
!!! Unknown header type 7f
I am doing the FLR using setpci as :
setpci -s 3b:00.0 0x78.W
2037
setpci -s 3b:00.0 0x78.W=0xa037
ffff
Can anyone tell the reason why the device is hung up like this?
  • Wincent_Altera's avatar
    Wincent_Altera
    Can I know which device that you are using ?
    also, which tile of AVST example that you are referring to ?
  • pdewanga's avatar
    pdewanga
    The device is 1SG10MHN3F74C2LG
    Using the Intel L-/H-Tile Avalon streaming for PCI Express
    Wincent_Altera
    Do you check LTSSM signal and ensure the card is able to link up ?
    Other than that, you may check the DIP switch and ensure that it is set to default setting.
    If not, I would like to suggest you to regenerate a new design example in the IP catalog and see if the same.
    Looking forward to hear back from you.
    Wincent_Intel
    Wincent_Altera
    I wish to follow up with you about this case.
    Do you have any further questions on this matter ?
    ​​​​​​​Else I would like to have your permission to close this forum ticket
    Wincent_Intel
    Wincent_Altera
    Hi
    We have not hear from you and this Case is idling. It is not recommended to idle for too long.
    Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
    Hence, This thread will be transitioned to community support.
    If you have a new question, feel free to open a new thread to get support from Intel experts.
    Otherwise, the community users will continue to help you on this thread. Thank you
    If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
    Wincent_Intel
  • pdewanga's avatar
    pdewanga
    Response- I tried capturing the LTSSM and link up signal on FPGA board after I do FLR.
    The link is up and LTSSM value is 11.
    Response - Can you please provide more details of the DIP switch?
    Response- I will do it and confirm.
    • pdewanga's avatar
      pdewanga
      Hi Wincent_Intel,
      I tried regenerating the Quartus IP and there also I am seeing same behavior.
      One more finding
      The flr_pf_active signal - output from Avalon-Streaming PCIe is zero after doing FLR.
      Please suggest is this correct behavior ?
      -Regards,
      Piyush
