pdewanga
3 years agoDoing FLR makes the pcie device hang
I am trying to do initiate Function Level Reset, on Avlaon streaming pcie hard IP, using setpci command and if I try to read the device back using lspci command the device is hang with ff as shown b...
Wincent_Altera
3 years agoHi,
Do you check LTSSM signal and ensure the card is able to link up ?
Other than that, you may check the DIP switch and ensure that it is set to default setting.
If not, I would like to suggest you to regenerate a new design example in the IP catalog and see if the same.
Looking forward to hear back from you.
Wincent_Intel
